FlatBlackBurb
i'm a carb noob.
i've never had to mess with any of the settings on my '69 caddy (only other carb'd vehicle ive owned until now) so i don't know what i'm doing. i did a search but didn't really find anything so i'll ask the experts.
what is a good setting for all of the mixture/fast idle/idle screws on my carb? the truck is a '77 camper special with a small block 400.
so far after i put the carb back together, i screwed the two air fuel mixture(?) screws on both sides of the bottom all the way in and then out 1 and a half turns each. i did the same for fast idle on the passenger side of the carb and the idle too. the bottom primary butterfly valves (sorry if i'm screwing up the names here) are barely open right now is that how they're supposed to be?
also when i pull the throttle, the bottom primary valves and then the secondarys open just fine all the way to WOT, but the primary valves on top open about halfway and that's it. the secondaries don't even open.
all the linkage is back the way it was taken off and that stupid manual that came with the rebuild kit wasn't very good or clear at all.
if theres a good thread on ck5 somewhere about this, please send me a link. i couldn't find it.
edit: i should add that when the truck warmed up, the idle was excessively high so high that the wheels would start spinning if you were off the pavement. even with the brakes on. throttle linkage seemed to be okay when i took the carb off.
i've never had to mess with any of the settings on my '69 caddy (only other carb'd vehicle ive owned until now) so i don't know what i'm doing. i did a search but didn't really find anything so i'll ask the experts.what is a good setting for all of the mixture/fast idle/idle screws on my carb? the truck is a '77 camper special with a small block 400.
