1) what should the screw for the mc solenoid be set to? Like how many turns out.
(not my carb, extra sitting around)
2) I have a spot where on full throttle where the car bogs. It's between 2500 and 3500 rpms. The o2 reads rich here .8 on the voltmeter and the dwell is at 38.
At idle the dwell varies 48 to 54. The o2 at idle is mostly at .5-.6 more often than it is down. The car seeks at idle on the gauge between 600-800 but I haven't put a real tach on it.
At regular driving around 2000 the dwell is in the 30s but can get up to 48. The o2 is a little lower on avg than idle.
3) the car idles higher with a vacuum leak (booster disconnected)
So it's definitely running too rich.
