Q's on ORD high steer stabalizer
Bossman1
Registered Member
Florissant Colorado
my buddys 89 k5 has one tons and he installed the ORD high steer and we would like to put on a steering stabalizer on it. any thoughts would be appriciated. thanks
There's room behind the tie rod and parallel to it. I built a simple bracket that bolted to the DS upper spring plate and put a tube clamp on the tie rod. Simple and effective.
:usaflag:
:usaflag:
cool man. thats the same path that we were thinking we just wanted to see if someone else has done it to see if it worked. thanks man!
