bp71k5
3/4 ton status
It seems like several people have posted about these fuel filters causing a lot of problems.
I have problems after removing a second inline filter (fram) right before the filter in the carb and it was running fine. Once I replaced my fuel line from the tank and mechanical pump, removed the inline filter ,and replaced the in-carb filter, I have gas pouring out at the top of the carb where this little plunger dips in. (see arrow).
Is this one of the typical problems with the filter? It's odd because it worked fine with the old filter in there so I'm not sure why adding a clean filter would cause problems. In any case, gas is getting in there ok so it would seem to not be plugged.
Any ideas what's going on?
I can see what looks like a black 4 sided rubber piece in the service manual diagrams. I assume that's what you mean.
