1) Pretty sure we have spark as i got one of those spark plug looking tester things and yes there's spark, plus i can occasionally get it started. The last time i was able to get it started was yesterday around noon.
2) Pretty sure we have compression......see #1 above.
3) No doubt there is fuel as i can see squirt if/when pumping throttle+ can see the float thru the small slot near the air cleaner stud.
i am leaning towards flooding too, BUT how could messing with the throttle arm/secondary linkage cause flooding?
Here's the best/only thing i can come up with:
In order to adjust secondary thottle opening, you have to bend tab "A" towards tab "B." In doing this, you'll soon find out that this also moves the throttle arm "D" clockwise towards "B" as well since "A" is directly connected to "D". So i grasped throttle arm "D" in order to prevent it from moving so i could bend "A."
i MAY HAVE, without realizing it, "OVER-ENTHUSIASTICALLY" twisted throttle arm "D" counter-clockwise----in order to counter-act the bending forces of bending tab "A" which would have been in a clockwise motion. (Note: Now that i think more about it, i may have used a wrench to hold the throttle arm.....)
This, in turn, caused tab "C" (the throttle arm stop) to also bend------which, in turn, now caused the PRIMARY throttle plates to now close up more or close up completely; This cause the stall out problem in the other thread and may be causing the no-start situation now----because the primaries have to be open at least a little in order to not only start, but to idle?
May be bunk. Irregardless of all that, we have yet ANOTHER problem(which may or may not be contributing to THIS problem) and that is the starter maybe/is likely hosed. It does not turn over very fast and cuts out---like the timing is very advanced, which it is not. Please keep in mynd this is a 4.3 v-6 and i can turn it over by hand---by the crank bolt and socket wrench fairly easy with only one spark plug out.
i did do quite a bit of cranking these past few days, but i don't think (hope) i overheated it. If it's an autoparts store cheapy, then i don't feel bad as i suspected i needed a new one anyways. If it's a delco-remy then i feel bad.
Battery tested good with load tester.
Can we discuss how to do a voltage drop test on the starter cables? And voltage drop in general?
