My 72 Jimmy has had some issues for a while. Hard starts, stumbling/dying at low cruising rpms, then just flat out died a couple times on my way home about a month ago. The engine was replaced around 86. From what I've found on the intranet, looks like the carb is from the late 70's.
Carb #'s
17054923
2688
Pulled my q-jet yesterday and plan on sending it to Jet for a reman job. I don't know much about carbs and really don't want to rebuild myself. But, have a couple questions. Mostly just for my information.
What's the solenoid looking thing up front of the throttle linkage?
Is this called a hot air or divorced choke? It's the kind that screws to the top of the intake. Also, what's the little yellow plastic diaphram connected to a vacuum port?
Kind of hard to see in the pic, but right in the center are 2 black rubber eraser looking things. Is that the JB weld fix I read about? One of them is coming loose/partly gone.
Carb #'s
17054923
2688
