Summary
A thread for the fuel pump and quadrajet combination --> overtime the thread increasingly focused on just the performance of the accelerator pump related to the fuel bowl volume after sitting for a few days. Meaning, it won't start like it should - I want to know why.
Read
I am reading through "The Design Evolution of the Quadrajet" written in 1966 by the designer of the q-jet Donald Stoltman. In the paper he explains that the small bowl design is intended to improve the angle before fuel spills out the nozzle and to prevent fuel evaporation since the dwell time in the hot carb is reduced. He relays that due to the small bowl design the fuel pump flow and maintaining pressure within +/- 2psi of design pressure is critical to performance.
There is a table here (I will add the image), it is difficult to understand but it looks like:
My K5 is backflowing fuel. I can see fuel backflowing through the clear fuel filter after I turn it off. The fuel pump seems to work fine, so the check valves must be good enough. But, as I understand it, the fuel should not backflow.
Intuitive Solution
So, I can buy a backflow valve and put it inline, or replace the fuel pump. If I replace the fuel pump, then getting the right flow and pressure seems important. Or, is a separate fuel pressure regulator a good idea?
Question
What works on your quadrajet?
Read
- Due to the needle seat design, for a 300HP engine fuel flow can be as low as 1 psi to supply 2.5 pounds of fuel per minute (ppm). I converted 2.5 ppm to gpm, it is .4 gpm ~ 24 gph at 72 deg F, not sure what it is at 100 deg+.
- 8 psi is required to maintain a constant fuel level, and fuel pressure should be maintained between 6 and 10 psi. I don't see how this 8psi relates to the 1 psi sufficient for 300 HP. I am guessing it must be volume/pressure related.
- By design, once the fuel level is over .25" from zero, it will 'blow-off'
Intuitive Solution
Question
