Oilbrnr
So, my new to me '77 died Sunday about a half mile from home. Loaded up the kids, and headed out with my neighbor to scout out this next weekends camping trip near Bartlett Lake right near our homes. He is a Ford guy, and joked with me that he had his tow strap ready. Never thought I would have to take him up on it, especially so close to home. I've had the truck for one week, and have been driving it every day to-from work with zero issues. On our way to the lake it just died going down our dirt road. (about 3 miles of dirt/washboard to the pavement). I smelled gas, and upon looking under the hood, gas was pouring out of the carb onto the intake manifold. An obvious stuck float/valve. Now I'm never going to hear the end of this from him! I've never had this happen on a carb, that I'd not just worked on. Pretty odd.
Went to NAPA today and got a kit, and what I thought was the correct filter. Did the standard disassembly and cleaning in Lacquer Thinner. Put back on truck and it will run for about 5 seconds. The fuel line is kinked at the flair nut by the prior owner. I was careful not to kink it more, but IMHO I think if must be restricting the flow. Either that or the fuel filter. The one I got from NAPA today was wrong, too long, so the filter could be an issue as well.
Any other thoughts? Again it runs great for 4-5 seconds and then that is it. Crank it, and it will fire right back up for the same duration. I don't think it would do that if the float was stuck in the 'up' position. Is that hard line from the pump to the carb a GM only part, or do you think NAPA would have it? Or do I have to bend my own?
FWIW, do the plastic/bakelite floats ever go bad?
