trevmountain
Kind of an update thread here. So as some of you know I sent off my older Edelbrock Quadrajet to Sean Murphy Induction or SMI for a custom rebuild to fit my application. Motor is also fresh and I am in the process of getting everything adjusted correctly. So far everything runs pretty good and I am trying to get as much info as I can regarding the fine tuning of these quads.
I started by adjusting my idle mixture screws to achieve maximum vaccum at the lowest possible smooth idle. I believe I have this as close as I am going to get it. I used a vaccum gauge and fiddled with it a few different times. With this being the only adjustment the truck runs pretty good but certainly does not feel optimal. At cruising speed I experience a slight uneven feeling or stutter. It is very slight, not a full on stumble. Basically she is just ain't purring like she should. Soooo should my next move be to start messing with the primary cruise mixture? Does this sound like it's running fat or lean?
Next symptom im experiencing is with the secondaries. When I mash it to the floor their is a pause or jump and then they open up. Like a wha-pause-whaaaaaaaa. I haven't started to mess with the secondary air door adjustment yet but I assume this would be my next adjutment? Other ideas for maximizing secondary opening?
I guess what I am looking for is a general step by step of adjustments to make and also what kind of response to look for when it's adjusted correctly.
