I have a like new quadrajet that has been sitting on my shelf for a few years and it doesn't look like I'll be using it any time soon. It was remanufactured back to factory specs with the base plate straightened, throttle shaft bushings, new throttle shafts, new butterflies, and all linkages are new. All the normal leak spots in the casting have been sealed with what is suppose to be an ethanol resistant epoxy. Was original for 67-74 (I think) Chevy 350s. I can get the numbers if you need to be sure.
Anyway I paid like $400 for several years ago and it has set on a shelf. It was installed to check operation before I purchased it but that is all the usage since rebuild. It's collected a lot of dust so a good washing with some carb cleaner will be necessary. I hate to let this go but everything I own is fuel injected or propane and I see no need for it in the near future so I would rather it go to a good home and be used. I'll start at $250 shipped, make offer if I'm too high.
My only disclaimer is that it has been sitting for a while but worse case is that it needs a gasket set and cleaning.
