Question about aftermarket door replacement
Satan bianchi
Registered Member
Nj
I need a replacement passenger door ...what I thought was just a one inch spot of rot on the outside ..apparently is much worse ..after looking underneath the door ...the whole bottom on the interior side is gone...is looked at aftermarket doors from 190 ..to 300 but they only show the outside of door ...this might be a silly question but I've never done any restoring ...is the inside panel part of the whole door or is it usually just the outer skin .....classic only shows the outside of the door not the other side
find a gm door . . . .
aftermarket shut like a soda can and half the weight of a gm door.
Thanks ...that's kinda what I was worried about ..and the search for one around here is turning yup nothing
Try LMC Trucks.com they have replace end. Doors and the insides ect. You can also get a catalog. I have gotten many part from them. Ripcord
I have some spares you can have. I was going to cut them down to make half doors. Where are you in NJ? Pm me, I don't come in here often and probably won't see a reply.
