If you had an older truck with 4 speed (80's) and a late model vortec (97 roller) engine with carb manifold, swapping to tbi without the EGR and using the 7747 ecm what BIN file would you start with? I have a "ASCN" "ARHT" "ASDW" available but the vortec heads is making me nervous. Anybody running anything close to this want to hook me up with a copy of thier BIN file to get me close?? I was told that the vortec head motor will need the 454 tbi unit to flow enough fuel and air, but GM makes a tbi manifold for the vortec motor with the standard tbi unit.
I've never tried to solder the broken off pins back on to the chip, because the heat used in the soldering is likely to destroy the chip. The internal circuits of the chip are easily burned with heat. The internal circuits of the chip are very thin traces only a few thousandths thick.
Make a best guess where peak torque (RPM / Vacuum) is and use that as the max degree setting. Set the distributor initial timing to zero. Maybe an old magazine article has a dyno of a 440 engine, and timing curve?
I like the option of an underhood ECM, and MAP sensor based EFI system for an off road use vehicle. The '7727 / '7730 are easily programmed to a different displacement, timing curve, and fuel map. I think with the correct ADS file, TunerPro RT can even data log the '7727 / '7730 V6. The '7727 / '7730 do not need a VSS, but a VSS is recommended. I think most, if not all 4.3 V6 MPFI ECM / PCM require a VSS.
