Question about doors
TerryD
Mildly demented...
Covington, Va
I've got two useable sets of doors from a 76 and 79 pickup. Will they work on a 84 Blazer?
73-76 internals are different, so if you dont mind having the older door panels, then no. Anything from 77-87 or 88-91 burb/k5/crew should be the same though. The early doors bolt up, but a few differences.
The body lines match pretty good? The older door panels don't bother me at all. The K5 has power windows and I'd rather have manual's for a trail rig. Not to mention the DS K5 door bottom is eat up with rust. On the off chance I wind up fixing the K5 door though, will the internals of either set of door fit to put the manual windows in?
Body lines are perfect, no problem there, but if you ever change your mind you cant fit your power inners into the 73-76 shells, completely different, but the doors themselves will bolt up and work fine as well as body lines match. Lots of guys put the newer power doors in their 73-76, so the opposite would work just fine.
