mollyman
This might be a dumb question but I'll ask anyway. I bought a 14blt from a military supply warehouse. It was unused, still straped in its original crate. There was painting on the crate that indicated the year 1982 and then tied to the axle itself was a card that the only thing on it still readable was the date 1982 so I am assuming it has been sitting in the crate since then. I popped off the cover and there was about 1 maybe 2 quarts worth of fluid in it, the gears were still covered with the yellow marking comound. The fluid stunk, I am assuming because it has been sitting there for so long, so I just let the old stuff drain out and filled it with Lucas and put the cover back on. Then I stared thinking should I be worried about any of the seals that were sitting in that old fluid for so long, will they break down? The oil that was in it did not look like it had broken down and turned "watery" it was still thick. I just wanted some input because I want to do things right. It is straped under my rig and I have done a disc brake conv. on it also. I have not driven on it because I have my body off right now. Any help would be great THANKS
