Well, I lost my momentum (again) last month when I got sick for over a week. I need to get back on it.
My axle housing was professionally blasted and then I painted it. I'm ready to start putting the guts back in it, with all new bearings.
My question is about a "setup" bearing for the pinion. From what I understand, you press off the old inner bearing and clean out the inside of it with a Dremel, so that it'll slip on and off the pinion easily. Is this correct?
Also, in terms of setup, am I to assume that all inner bearings are the same thickness? Because in my mind, pinion depth would change when you swapped the setup bearing for the new bearing.
Discuss.
Discuss.
Actually, they work.
