dbreid
All,
I am very excited to be finally heading up to the Dusy-Ershim trail in a few weeks, and I am trying to go through my truck and make sure anything that needs to be maintained is maintained, and anything that needs to be tightened is tight, and anything that needs to be adjusted is adjusted BEFORE I go.
And it occurred to me (probably not a shock) that at altitude (10,000 feet) there will be a lot less air, and therefore, with the jetting in my carb, I'll likely be running rich. Not to mention I will have less power (less air = less power).
Are there things I can adjust when I get there to help it run a little better? The 454 has so much power that even with a loss, I'll probably be fine, I just don't like the idea of running rich for 4 days, and burning all my fuel doing nothing.
Also, in your answers, assume I know very little about carbs. I get the concepts, and have worked on them lightly (fixed stuck floats, cleaned them, etc), but never done many adjustments, or tuning, or re-jetting etc.
Thanks in advance!
-Dan
Thanks in advance!
-Dan
How about oil? I have never spent a week (4-5 days) at 10K feet. Should I change anything else?
