Copied from Pirate 4x4 thread. You can put any fancy name in front or behind the words tapered reamer but a tapered reamer is a tapered reamer.
Quote:
TRE
taper Reamer info.:
1.5" inch per 1 foot= 7.125 degrees=7 degrees 10minutes
FYI, here are some other specs I collected from the 'net:
· Big taper = .667-.776 (3/4 and one ton stuff with 7/8 -18, and ES375[
'67-'72 1/2ton & 3/4ton GMC] with 3/4-16 and dog-leg))
· Medium Taper = .636-.714 (moog ES150 with 3/4-16) FORD TRUCK F100/F250
61-65GMC TRUCK K1500/K2500 63-66
· Small taper (stock jeep XJ) = .531-.675
7 DEGREE (1 ½” PER FT.) TAPERED REAMER
(there are quality differences, so shop appropriately)
BC Bronco $75/115
Afco # 80770 $120
Stock Car Products #R8201 $105
Goodson #TR-216-2 $80:
http://www.goodson.com/store/templat...9cb1ea35162f15
Snap On # R121 $46.70
I could only find these suppliers online of such a reamer, obviously the Snap On model doesn't work well. This is where I found the info and has links to the mfg...
http://www.deepsoutheb.com/CTRconv.html
Available:
Afco Racing:
http://www.secureperformanceorder.co...ProductID=2631
PRODUCT: 80770
Taper Reamer - 1 1/2in./ft. (most Tie Rods & 20031, 4, 5, 6)
Manufactured from M2 High Speed Tool Steel
that is heat treated to 62 - 64 Rockwell.
Six flute LH spiral design allows smooth boring operation and minimizes tool wear.
Less likly to score the finish than RH or straight flute reamers.
Two designs to cover most popular racing applications.
Part: 80770 Price: $119.50 Quantity
Stock Car Products:
http://www.stockcarproducts.com/susp13a.htm
Tapered Reamers
Manufactured From Superior Quality High Speed Tool Steel
Six Flute Spiral Design
Allows Smooth Boring Operation - Minimizes Tool Wear
The Same High Production Units Used In Our Plant
Part No. Description Price Click
To Buy
R8201 1 1/2" Taper Per Foot. Fits most tie rods and shock mounts (K6024, K772, K719, K727) $105.00
BC Bronco seems like the best option:
http://bcbroncos.com/store/advanced_...8c38d6&x=6&y=9
Displaying 1 to 2 (of 2 products) Result Pages: 1
Buy Now Price Product Name+ Manufacturer Model
$75.00 Economy Reamer 97-20000
$115.00 Pro Reamer 97-10000
