Question about using larger 9/16-inch diameter grade-8 U-Bolts...
So, if you buy a set of Zero Rates from ORD, make sure you get the U-Bolts from them as well because no major off road suspension company has them.
Strike that! ORD does not have the correct U-bolt...at least the length U-bolts I want.
I've always just had my own u-bolts made. Just look for a spring or big rig shop and most of them can make them for you to any dimension you want.
