Trying to install these darn things but have hit a snag. After putting them mostly together and about to do the dial, I've noticed there is nothing holding the axle shafts out. Meaning: the stub shaft spindle seal has no reason to stay against the spindle. In Yukon's instruction (which I've followed to a T) the end result is the same. I can see it in the pictures. There is about a 3/16" gap between the circle clip and the flange.
I think pictures work best. Here are a couple. The black flange cannot go out any further because the dial hardware and circle clip won't allow it. Seems like it needs another small spacer, could be nylon.
Ready to finish install. Will update with any fitment problems. (dial/cover)
