Question for you jeep guys (for a friend)
NEK5
3/4 ton status
Ipswich MA
A buddy of mine picked up an old jeep (42' I believe). He's having a little carb trouble. He's wondering if there's a way to fix a stuck needle without having to spend the cash on a rebuild kit, as the internals all look pretty clean. I haven't messed with carbs enough to give him any sort of useful advice. He thinks it's stuck closed as the carbs not getting any fuel. What say you?
Thanks in advance :)
He might be able to just take the carb apart and free the stuck needle valve up and clean up any crap in there with a spray can of carb cleaner,but most likely the gasket wont survive the removal process,so he'll probably have to get a jiffy kit to rebuild it...I have not bought one in years myself,so I cant say how much that will cost,but if its a 1 barrel carb I bet its less than 15 bucks,but he'll probably need carb numbers to order one,I doubt a store will have on on the shelf for something that old..
I would try spraying carb cleaner in the fuel inlet where the gas hose connects,and down into the air bleed tube up top --that'll fill the bowl up and then it can soak in awhile and hopefully dissolve any varnish holding the needle valve closed,then tapping on the carb near the needle valve with a screwdriver handle might free it up,if its just stuck closed...
First things first. I would assume there is a mechanical fuel pump being from 1942? or did you mean a 4.2 carbed straight 6 from the 80s. Either way, remove the fuel feed line from the carb and place into a bucket or jar and crank the engine over. Does fuel come out?
Start there.
