??????question of the day.............
boggerless
1 ton status
dearborn heights, Michigan
my friend john just came in and said his battery fell over and the posi cable was on the body for about 10 17 minutes. so now in reverse neutral the volt guage is normal but in drive it burries in the negative and everything dims. but the high beams come on dim also.it does start.???what could it be ??? thanks he's here now:D
Sounds like he melted a fusable link and now the alt is not charging. With the truck off, chaeck for power at the big wire (on the stud) at the alt. If there is no power you are going to have to trace the wiring back to the battery and find the open (melted fusable link). If it is an older chevy Most of the links are down by the starter.
