mikekwesell
Registered Member
Hi Gang, I have a 1973 K5 Blazer that I put a 4" lift on and threw on a set of 16" wheels with 35" tires. Do I need to swap out the transfer case now? Or can I somehow adjust/change the gear ratio in the transfer case that is on the vehicle? Please see pic of tag on transfer case - still not sure what this tag tells me about the current gear ratio. Thank you in advance for your help!!
