Ok, so I went to change my thermostat (doing a radiator/hose swap, so figured I might as well), the bolt broke, and I drilled out the bolt because it wouldn't budge after PB, heat, and an Easy Out attempt.
So, I just re-tapped the hole with a 5/16-18 sized tap. I installed a new bolt from Home Depot (stainless) with some anti-seize on it.
I filled up the radiator with water and ran the truck for 10 minutes w/ the heater on high and so far no leaks. I plan on getting the coolant flushed at the shop tomorrow so everything is fresh.
Is there anything I missed in performing the bolt extraction/rethreading that may cause it to leak in the future? I've heard people talk about heli-coils but since I was able to retap the hole, is that necessary?
Thanks!
Thanks!
that just makes no sense if you think about it the coil is stronger than alum and now the hole its in is larger for more surface area in the alum to hold it.
