question running new brake lines
westn11
Northern VA
I purchased a used Hydroboost setup from a fellow board member a few months ago. My truck was going to be down for a while so I decided to send the Hydro out to Vanco for a rebuild, and he sent it back with a new master cylinder attached. I'm about to run all new SS brake lines on the truck and was curious about which port goes to which end of the truck?? I think he said that the brake outlet closest to the firewall goes to the rear brakes, and the outlet closest to the radiator goes to the fronts. Is my memory correct?
-Nigel
