I just picked up a set of 56" springs for my shackle flip, currently it is 9 leaves (8+1 overload). How many leaves are you guys running? Are you using your overload? I won't be towing or hauling anything.
That is an excellent question rampage, and an important one.
First of all, to answer your question, the answer is yes.
Secondly, to those unfamiliar with the term "radius", it is simply rounding off the square edge of the zero rate (or in my case, overload spring) where it comes in contact with the leaf above it.
The purpose of the rounded edge is so when the vehicle is being flexed and stress is put on the contact point between the zero rate and the leaf, if the corner of the zero rate is NOT rounded off, or "radiused", it will basicly dig into the leaf causing stress risers in the leaf.
Over time, this causes damage to the leaf pack inevitably destroying it, and before too long you have a very heavy paper weight.
I was considering removing the overload and possibly the next spring. The pack has two springs plus the overload that isn't being held together by the clamp looking thing on each end of the spring
