Question
They fit, and they're not physically bigger or anything. They make as deep as 5.13:1 for the 10 bolt...
Rene
might need a diffrent carrier the ring gear bolts to. depends on the ratio you have now if reusing the stock carrier. if arb air locker / detroit full locker/ full spool or other full replacement carrier then just get the one you need for the ratio you are getting.
sounds like big tires for a 10 bolt
not sure what the split is or if there even IS a split, but find out if you need "thick" cut gears or "standard". All depends on the carrier gear mating surface thickness, or "size".
