question?
nicotine
i was helping a friend install a ORD shackle flip on his blazer and when we went to put the shackle up all four front faceing bolts lined up great but the bottom did not? is this normal? by not running those 2 on the bottom is he risking to break anything untill he can drill his frame out to fit? /forums/images/graemlins/ears.gif
mine did the same. u have to have them. w/ the bracket bolted to the truck/K5 just take a drill w/ the right size bit & drill the frame out so the bolts w/ fit.
yeah thats what i figured but he cant do that till tuesday will it be fine if he is easy with it? he has no drill till then.
so i am guessing that it wouldnt be bad to run without the two for a day.
