Questions about Scan tools
Eric M.
Oakland, CA
I've got the little "plug in tool" that puts the computer in Diagnostic mode and makes the SES light flash codes. After reading a bit, I'm under the impression all it does is short the A and B connectors together, just like the paperclip method. Does this $20 tool do anything more than the paperclip?
I've noticed that the GM Service Manuals often call for grounding the A and B terminals (like mentioned above) to perform certin tests. I have an Auto X-Ray Scan tool. From what I can tell, there isn't a mode on it to ground those 2 terminals. I can pull codes, monitor engine function, but, it can't put the trucks computer in diagnostic mode like the paperclip does. Am I right about this?
Lastly, the service manual talks about reviewing engine performance over a period of time. That a Scan tool can collect engine data every few seconds and somehow let you view it later. Example - I'm getting an intermitent code 44 (lean). The manual tells me to hook up the Scan tool and drive until I throw the code, then review the Integer and Block Learn at the time the code 44 was throw. Is there some way to review or download this info. onto a PC so I can view the other engine functions at the time the code was thrown?
Thanks,
Eric M.
I donno about most of your issues, as my trucks are all pre-TBI (mmm, got dizzle for shizzle!)
However, I gather that WinALDL is popular for logging:
http://winaldl.joby.se/
-- A
