Looking for a little help understanding AFR's. I'm setting up the tune on my FiTech, and am reading pretty consistently, that "big blocks like to run a little rich". That doesn't make sense. Other places, almost all of them, are saying you need to set the AFR up to your individual engine, some run better rich, some better a little lean. Here's my question: From a math and chemistry standpoint, 14.67 to one is ideal for gasoline. Now, I understand that there are a ton of variables here, such as air density, gas additives, even humidity. But generally speaking, when you lower the ratio, making the mix more rich, does that produce a more powerful explosion in the cylinder? Is that why they say you want to run rich during acceleration? Seems to me ideal would be ideal, meaning you're using all the gas and all the air, meaning you should set it to 14.7:1 no matter the rpm or map load. But obvioulsy this isn't the case. At some point, on the rich scale, though, you run into a mixture that won't ignite. Same going on the lean side. How much of this is science and how much is hot rod legend? What type of ranges do the OEM's set up in thier tables, and is there any way to find out, or is that a closely guarded secret? If anyone knows a good article, point me to it..I understand this is a lot to explain in a post, but I'm just not buying that there is that much of a variation in "ideal'. If you can burn more fuel, and more air, then that's ideal, but either exiting the cylinder is going to be less than ideal, right?
