sope
I have several engine questions. I have an 87 TBI 305 with about 175,000 miles on it. I'm still running 10W30 in moderate temparatures. Engine runs good and doesn't burn much oil. It has been maintained well for the last 100,000 Miles. It is in my truck wich is primarily a trail rig now.
1) It has just recently started ticking out of the right bank only after several minutes of high load and high RPM. (Usually 4 low on climb). The tick goes away after I take it easy for a couple minutes. I believe this to be a collapsing lifter but it also could be sticking. Any opinions?
2) If I replace lifters I will likely replace the cam. I would like to give it a little more go, low end preferably. I'd like to keep this simple without rechiping.(money's a little tight) Can I do this or should I just inspect it and go with the stock one if needed.
3) Anybody know if this engine has plastic or metal teeth on the chain?
I't's not rattleing but it's probably time.
Any opinions are appreciated.
That needs to be read carefully...it doesn't say you HAVE to get a chip burned, just that it needs done so it would run as good as possible.
