QUestions? Questions?
CHEVYDADDY
BARDSTOWN KY
First i have a 85 k5 now with 350 0.40 over and 4 speed running 32" bfg mudders so now i have my engine in and putting every thing back together! i have a lot of vac lines what can i lose? a/c had to go no smog pump.
brakes use vac.
have little round bucket in drive side frender wheel carcoal canaster all vac lines go to and from? can i lose it can i lose some of it?
power steering pump spacer?(how big is you spacer?) im taken out the old a/c bracket and putting just the power steering pump back
what is the thread count and size for motor mount bolt need to buy new nut for mount. (Hint truck is at budys house) put the bolts in before thinking.
throw out bearing where does it go? (might have f**k up) not sure if i transfered it
might have more any help is weclome thanks to the CK5 fourm ive learned alot and just been reasured on others any how thank for the help:confused:
