Queston on eliminating rear end sag
Ressurection
Prairie du Sac, Wisconsin
I was planning on a 1 to 2" lift in the back to improve looks/stance on my 72. Originally looking at blocks but then saw 'helper' springs in Whitney. What are the pro's and con's to both situations? Also, Whitney for suspension parts-good or bad?
Thanks!
The helper spring will stiffen up your rear springs. If your just wanting to level it off and 1 to 2" does it, I would just use blocks. If you were going to lift it, you would want to get a taller rear spring if that was affordable for you.
If you add block just beware that lifting block on first gens won't fit if you still have square style U bolts with the anchor plate on the bottom of the axle tube....if it's round style U-bolt with the anchor plate on the top you should be fine.....you can make blocks work but its a lot of work to do it right....
Sorry, I couln't resist..
I used helper springs on mine, it worked and was simple to do...
John
