Quick 14 Bolt Question
79Stomper
Forest, VA
I am putting my 14 bolt back together after 4 months or so of dis assembly so forgot something.
On the 6 point nut on the shaft, how tight do I put that nut? I have one tight as can be and the wheel won'tmove. The other I have it snugged and the wheel moves fine so which one should I go with?
Quickest replies appreciated as I am doing this right now.
TIA:thumb:
James
That is what I am thinking too, but I just want to make sure. Hate to be going down the road and smoke the bearings.
I've always torqued the inner to 50ftlbs and then backed off 1/4 turn. The outer I also torque to 50ftlbs and then carefully tighten it until it lines up with the lock washer. Don't know if this is the text book way but it's always worked for me.
Yeah, that is what I do for the front as well, But what about the rear? There is only one and it snugs against the outer bearing with a metal lock that fits in between the nut and the shaft then a lock ring goes over that.
Eew... can't help on that one. I have the older style nuts (2 nuts w/ washer in between, like a front), I haven't dealt with the single nut/keyway set up yet.
:dunno:
If ya can't find the spindle nut's I have a couple of extras if ya need em.:xmas:
