quick 14 bolt question
Ring gear, no assembly. But a ring gear has a mated pinion gear to go with it. Don't interchange them. The carrier could be called an assembly as it has a few spider gears/clutches/shafts...depending on type. The ring gear bolts to the carrier, the carrier bolts into the differential axle housing.
Some people call the ring and pinion a "ring gear assembly":waytogo:
