quick bearing question?
boggerless
1 ton status
dearborn heights, Michigan
is the inner hub bearing the on a k-20 44 the same size as the k-10 10bolt? the 10 bolt in JR is making funny sounds:laugh:i don't have the loot right now to buy a new set, but the 44 has usable bearings .are they the same?
If the K20 has internal hubs (do they look like the ones on your 10B??), then the bearings will interchange. If the K20 has external hubs (hub asm bolts on with six 3/8" bolts) then the bearings will not interchange.
