Quick check on rims
us74k5
oregon
Rims on a 95 3/4 ton burb, are they the same bolt pattern as the 3/4 ton axles from an 84 burb? Fairly certain they are, just wanna make sure before i buy them.
Yep, stock for stock the same the b/s will be different but new wheels will fit older trucks.
Yes :rolleyes: , bolt pattern is 8 on 6.5" , all 8 lug GM and Dodge have always been this pattern and ford 8 lug was up until the body style change in 99 (now they are 8 on 170mm).
As mentioned the back spacing is more on the new rigs though. May run into clearance issues up front with the Tie rod ends.
