Quick Help! hydro ram connection Q's
Fancy
Reno, NV
My box is tapped on the side, and my ram is mounted with the body on the diff and push rod on the tie-rod. Now i have been told before but always forget!:doah: So help me out I connect the body side of the ram to the lower tap on the box and the ram side to the higher tap on the box? Right?
Not a clue personally, never had to fool with one.
But it should be simple. Just flip a coin, hook the lines up, and either gently turn the wheel slightly, or better yet, disconnect the rod end and see which way it moves.
Should be obvious real quick.
Ya that's what i'll have to do i was just hoping to find out before i have to bleed the system and go through the steps thanks for the reply though?
The bottom line on the steering box (closest to the sector shaft) goes to the fitting closest to the shaft of the cylinder (tie rod side).
