I tried the sawzall method to no avail. Blade kept skippping around. I took it to work and used a press with the appropriate sized socket. One that fit the diameter of the sleeve perfectly and a bit bigger one to fit the diameter of the spring eye and used a press. Same way you would change out your u-joints.
