Stupid NEWB question!
So I'm doing an oil change and forgot to prime the oil filter. Right now, the level is slightly over full with 7 qts of oil. I tried cranking the engine over for 10 seconds to prime the oil filter to no avail. I want to check and make sure I'm not going to air-lock my oiling system by turning the engine on....
So, can I fire it up and let the engine run to purge the air, or do I need to pull the oil filter back off and prime it manually?
So I'm doing an oil change and forgot to prime the oil filter. Right now, the level is slightly over full with 7 qts of oil. I tried cranking the engine over for 10 seconds to prime the oil filter to no avail. I want to check and make sure I'm not going to air-lock my oiling system by turning the engine on....So, can I fire it up and let the engine run to purge the air, or do I need to pull the oil filter back off and prime it manually?
