Stomis
Professional Amateur
Still shopping for a work truck. Ive seen two light duty 6 lug 2500s so far. Im curious if they are a stick is it an NV4500 or an NV3500? Also is it still a 3/4ton capacity frame?
I had one. Mine had a 700r4. Was 7200gvwr iirc. From what I could tell, it was just a half ton with the sf14 bolt, and maybe one more leaf in the spring pack.
I have heard the W/T trucks had the v6 and got a nv4500 .
my buddy got the tranny from 1 of these trucks .
This is true. I verified this on a 2wd 1/2 ton v6 with vin Z (4.3) and RPO MT8 (nv4500)
was baffled at it, but it was sweet at the same time!
good luck with the truck search. yea at least a 4500 will be a easy swap if you get a NV3500 truck. If you end up needing a 32 spline input for the t-case, let me know.
