Quick question on the military blazers
The1980BEAST
Ft.Worth Tx
I'm looking on bidding on one that has the 6.2l diesel. What type of axles did they have under them?
ahhh so no good 3/4 ton axles :( ...so there is really no point in buying one... Is there any military vehicle that ran 3/4 ton - 1 ton axles?
yeah the pickemup version. and the ten bolts are half tons.
the truck came with 4.56 gears and a detroit in the back on one tun axles. hot stuff!
The Military Blazers are "rated" at 3/4 ton but they're basically identical to a civilian Blazer (i.e. 10 bolts etc.) other than a 24V electrical system.
Are you looking at the white one in Watauga? I've been trying to get my dad to swing by and take a look at it. He lives right over in NRH.
Im biased, but i LOVE my M1009, and would never look back. They are excellent trail rigs, but of course, we all want 1 ton axles (ive got a set of K30 Dana's in the wings) but the question is do we NEED 1 tons. My M1009 has never gotten stuck, and never broken a suspension part, although the springs are worn out. Although i dont wheel the wee out of it, basically some offroading, trails, creeks, and mild rocks (think pebbles). I ran 33's on it and had a blast. In 4 low i could get through just about anything i ran up against, again, no sand, no major rocks, no competition stuff, but i did get it up to the "crease" in the body panels in muddy holes a few times. Only thing that ever broke was a battery came loose and took out the radiator. I managed to plug the hole with a wine cork, fill it with stream water, and drive it home. OH, and with those 10 bolts with 3.08 axles, 33in tires, the HD TH400 and the 6.2 diesel, i could effortlessly get 20+ mpg on the road to and from the trail.
The only, and i mean ONLY reason im upgrading to 1 tons, is vanity really. I wanted to run H1 beadlocks, so i needed big tires, which means i needed clearance, and DRW axles to fit the H1's without spacers, and i want to eventually do some more serious wheeling. But for what ive actually used the truck for, and as a general use, all around truck for camping, trail use, moving furniture, driving to the beach and all that, the M1009 is IMHO perfect as is. maybe a 4in lift and 35's to be the cherry on top.
So it really all depends on what youre gonna use it for.
