quick shock mounting question
muddysub
1 ton status
Staff member
Moderator
North Branch MN
how important is it that the shock eyes are parallel to each other? i.e. the upper and lower mounting bolts both pointing from front to back on the truck. if i built new lower front shock mounts would it matter if the lower end of the shock is turned 90* from the upper?
Besides potential bushing wear, I can't see it making a difference. And shock bushings are cheap.
