So i have installed Bowtie Overdrives TV MADE EZ kit. upon connecting the throttle cable i realized it is slightly to long. The W.O.T. at pedal dose not match W.O.T. at TBI. Honestly i think it has slightly been off for awhile however the kit seems to have exaggerated the difference.
Any way i want to simply shorten it up a little and put it back in spec however i am not familiar with this. It looks as if the end is simply a ring terminal? Is there something special about it and can i buy it at a parts store? What is it called? Maybe something else you recommend to use for an end?
Or better yet is there a way to shorten the cable slack from the inside?
