Quick wiring help
45acpJr
Tucson, Az
Ok Im in the middle of a complete re-wire. I was pretty good about taking notes and what not but I clipped the brown wire that crosses the firewall then goes down and under the truck to the dual tank valve. Where does this wire go? Does it get constant power from the fuse block or does it attach to the switch inside the cab? I know the info is searchable but I need to get back to work....thanks guys:waytogo: By the way this project sucks but needed to be done
