^^^^ What he said. Unless your dealing with alluminum heads. I believe they have the holes the same angle as the older heads. It's not that hard to drill the holes out. I've done two intakes. If you do it, make sure to put the angle going the correct way. I accidently did two holes going the wrong way. Nothing some silicone couldn't fix though.
