NEK5
3/4 ton status
Looking to pull my old window out of the 82 cab, and replace it with my new slider, as well as replace the weather stripping at the same time. Any tips?
NopeUse lots of soapy water solution and you'll be fine. Do you know about the rope trick?
Care to share?
I think I get it, thanks Scott, I'll give it a shot!When you have the glass or slider window inside the rubber seal you'll take maybe a 1/4" diameter rope and run it in the seal groove on the outside and leave enough rope for you to pull on. Now set the window into place and using the soapy solution spray it heavily around the rubber seal while you start pulling the ropes (one at a time is fine) this will bring the rubber over the edge of the steel cab. Just be careful when you get to the corners. You may need to also have someone carefully help you push here and there as you go.
For my next trick I shall require a spoon, two heads of lettuce, and a volunteer from the audience.
