3MAX
I'm cleaning up the wiring on my 1990 K5. Where should the high pressure switch on the compressor wire into? The wire from the switch is broken and missing. I'd like to wire it back up correctly.
I have a 91 Sub and it only has the low pressure switch near the dryer.
I honestly don't remember seeing a high pressure switch on mine, it's an '89 though. All I remember seeing are the wires going to the compressor, and the wire for the pressure switch on the accumulator, low side.
I'm not stating facts of it being there or not, just saying, I don't remember seeing a high pressure switch.
I seem to remember that being one of the biggest things as to why it's best to have a high and low pressure manifold gauge set on it, to read what both sides are doing, reading the low side to get it to where it's supposed to be, but if the high side gets too much going on, it's usually an o-tube issue or some sort of blockage deal.
Been a short time since I've messed with them though,,, could be something different I'm not remembering on this model.
Do you mind taking a look for me? Sounds like our models were not originally equipped with the high pressure switch. In that case, I'll just leave it unhooked.
