bp71k5
3/4 ton status
I had my motor overheat a few months back because I forgot to plug in my electric fans before a drive. I saw my coolant temp gauge pegged and then then the upper radiator hose came loose spraying steam and coolant everywhere.
Now I've got a small leak somewhere in the fins of the radiator and I'm wondering why the radiator cap didn't pop to relieve the pressure before it damaged the radiator. Assuming this is the cause of the leak.
Is there a way to check the function of the cap? Or would a secondary pressure relief valve be useful?
-Brian
-Brian
