goathearder
Hey All,
So I have a 73 K5 with a 91 front end swap and I need help with my cooling system. The PO put in some stupid tiny little electic fans and I need to ditch those cause they are not cooling adequately in off-road situations. I want to go back to a standard mechanical fan for simplicity and reliability but I have a few questions:
1) I found a shroud at the JY that fit to my radiator top bracket so I am good there. It has about 9 inches from the center of the water pump to the bottom of the shroud so I assume that means I need a 18 inch fan. I also assume I need a clockwise one (standard rotation). The real question is do I need severe duty, standard duty, or heavy duty?
2) This brings me to the clutch, do I need severe, standard or heavy duty (assuming it matches the fan choice). Do I even need a thermal clutch at all or does a non thermal clutch work too? What came stock on the 73?
3) I am putting in a new radiator too, looks like they were all the same size from 73-91 but do they have the same mounting??? Do I need either the 73 or 91 or will both work? Will the support pads from either work as well? Should I get a 2 row or 1 row? According to the website they both have the same thickness so what is really the difference?
4) Lastly, is it ok to run the radiator top bracket and shroud from a 73 on a truck with a 91 front end swap? I don't see why not so long as everything is centered but I just want to make sure.
I know this is a lot of questions but I am very confused so any help will be appreciated. I also have a winch mounted on the front now if that makes the fan/air requirement any different.
Thanks,
John
Thanks,
John
