RJB44
I have a 1991 GMC jimmy which has sprung a leak. I came out this morning and it has a pretty steady drip. It doesn't appear to be the hose connection of the bottom left (if standing in front of the truck) but more so to the right, maybe two inches to the right from the lower hose. It seems the leak is right around where the left side bolt for the plastic radiator shroud (motor side) is. I can't see exactly where the leak is, unless I removed the shroud piece. I'm not sure if there is a fitting, or smaller house connection.
I have not R&R a radiator before, so not quite sure what is involved. I don't have a whole heck of available time for DIY, so I am wondering what a shop might charge my for labor on this job. I'm not sure if this is a common leak and easy fix. This may be the original factory radiator?
Finally, how does any of those aftermarket radiator leak products work? I picked up the AlumAseal Radiator Stop Leak & Conditioner from AutoZone this morning, but haven’t put it in. Is using these products risky for other damage?
